can u cut springs on a neon
Old Apr 6, 2009 | 06:39 PM
jokerfire's Avatar
jokerfire
Default can u cut springs on a neon
can u cut the springs on a 2 gen. neon?
Old Apr 6, 2009 | 10:05 PM
spikeymikey87's Avatar
spikeymikey87
no you cant cut springs on newer cars. the heat from the cutting will ruin the metal and make the spring stiff. just spend the money on lowering springs theyre not that expensive
Old Apr 6, 2009 | 10:21 PM
ewetho's Avatar
ewetho
Sure all day but the results will be an unsafely lowered car that is mores susceptible to failure.
Get lowering springs if you want to drop your ride.
Old Apr 10, 2009 | 02:33 PM
neonftw87's Avatar
neonftw87
and the camber kit.... did anyone every find the kit to reallign you car once you lower it?
