Old Aug 6, 2015, 12:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
water leak on passenger side under dash
Old Nov 8, 2012 | 03:39 AM
  #71
darthroush's Avatar
darthroush
Section Moderator
Originally Posted by jaguarflush
Its your ac drain pipe which is on the wall of your engine it will be blocked .
causing the ac unit to fill with water and run into your passenger well its about four inches long just pulls off, clean it out it will be full of mud and clean also water should run out when you pull it off the car when cleaned it simply pushes back in the hole your car should be dry in a few days for good.
Would a blocked AC drain pipe cause water to pour into the cabin due to the car simply being parked outside while it's raining? First time I've heard the A/C drain pipe mentioned...
