Old Aug 6, 2015, 12:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
water leak on passenger side under dash
Old Jul 13, 2011 | 05:40 AM
  #61
johni86's Avatar
johni86
Originally Posted by darthroush
Follow the instructions on the first page?
Since I do not understand where it must be put...
I will burst all of my silicones there now. dammit.. : /
Old Jul 13, 2011 | 10:10 AM
  #62
Michael4824's Avatar
Michael4824
If that corner in the picture is where the a-pillar, front and side cowl meet (it's hard for us to know exactly where that is since it is zoomed in so far; we can't see where that is in relation to the rest of the car), then yes.
Alright, thank you again. I'm just waiting for the sealant to dry before I pull out the garden hose.
Old Jul 13, 2011 | 04:28 PM
  #63
darthroush's Avatar
darthroush
Section Moderator
Step #6 of the instructions I said to look at:
6. Locate the large vertical and horizontal sealer beads near the right outboard cowl grille screen mounting screw attaching point (Fig. 1). The sealer beads are at the junction of the A-pillar, cowl plenum upper and cowl side panel. Apply Mopar Silicone Windshield & Glass Sealer, p/n 04467708, to the outer edge of all existing sealer beads.
Old Feb 9, 2012 | 02:22 PM
  #64
CBJackets's Avatar
CBJackets
Sorry to bump an old topic, but same issue. I've tried to seal it as many have suggested, with no success. Mine only occurs when I have take air in from outside. If I choose to recirculate the cabin air, then it's fine. Wouldn't be much of a problem if my windshield didn't fog up whenever it rains, which means I must take in air from outside.
Rustproof mentioned cleaning out the airbox. Is that referring to this part? (Was a little confused since he mentioned taking out the blower motor, which to me, doesn't seem related to that airbox.) If so, mine looks fine, not clogged. Any other ideas as to where it could be?
Old Feb 9, 2012 | 02:29 PM
  #65
darthroush's Avatar
darthroush
Section Moderator
Not that part, no. There seems to be some other kind of box under the dash that he is referring to.
Old Feb 9, 2012 | 03:36 PM
  #66
CBJackets's Avatar
CBJackets
I looked under the dash (on the passenger side), and to me it looked like only the blower motor easily came out. I didn't take out the glove box because I wasn't sure how, and it didn't seem necessary in order to access the blower motor. Any idea on how to remove it?
Also, I just want to double check that this is the air intake for the cabin in an 05.
Old Feb 10, 2012 | 12:12 AM
  #67
darthroush's Avatar
darthroush
Section Moderator
Never done it, but usually you remove any screws and then squeeze the sides. And yes to your question.
Old Feb 10, 2012 | 09:28 AM
  #68
CBJackets's Avatar
CBJackets
Alright, thanks. I'm gonna give it a try this weekend.
Old Nov 7, 2012 | 05:27 PM
  #69
jaguarflush's Avatar
jaguarflush
Wink water leak in front passenger side
Its your ac drain pipe which is on the wall of your engine it will be blocked .
causing the ac unit to fill with water and run into your passenger well its about four inches long just pulls off, clean it out it will be full of mud and clean also water should run out when you pull it off the car when cleaned it simply pushes back in the hole your car should be dry in a few days for good.
Old Nov 8, 2012 | 02:15 AM
  #70
arnonefrank13's Avatar
arnonefrank13
get some silacone a goop up everything...lol i would its prolly a weather stripping problem when it rains hard....just because the puttle is there doesn't mean thats where its coming from....could roll down and around things before gravity brings it to its lowest piont....thats how i find leaks...just tring to help ya
