Help 2000 dodge neon doesnt start
Old Apr 22, 2009 | 12:57 AM
darthroush's Avatar
darthroush
Section Moderator
That light comes on for a reason, and it seems you now know why...
Old Apr 22, 2009 | 01:26 AM
pyrochin's Avatar
pyrochin
ya i guess i need to take it somewhere thats not the dealer. they just expect me to give them 900$ to change my cam sensor and crank sensor and still cant tell me if my car will start once they did it
Old Apr 22, 2009 | 02:11 PM
darthroush's Avatar
darthroush
Section Moderator
If you've got an engine light, and can get the codes, I can tell you what it is...for free.
Old Apr 22, 2009 | 09:42 PM
pyrochin's Avatar
pyrochin
the light is only once when i put the key in then it turns off is that normal?
Old Apr 22, 2009 | 11:34 PM
pyrochin's Avatar
pyrochin
so my car backfired through the air intake so im guessing my timing belt sliped?
Old Apr 23, 2009 | 12:36 AM
darthroush's Avatar
darthroush
Section Moderator
Turns off when you turn the car on? The CEL will come on if the key is in the on position, but the engine isn't running.
Old Apr 23, 2009 | 08:29 AM
N3ON's Avatar
N3ON
wow guys.everyones neon is jerking a ****ed up and **** DAM!!!!
Old Sep 17, 2009 | 08:35 PM
thataway5000's Avatar
thataway5000
would a bad cam sensor cause the plugs not to spark?
Old Sep 18, 2009 | 02:03 AM
neisg1's Avatar
neisg1
From what I have read the engine will run in limp mode with a bad cam sensor but, it will not run with a bad crank sensor. Also check or swap out the auto shutdown relay. In 1st gen. Neon’s the auto shutdown relay cut power to the, fuel pump, injectors and spark. The second gen. also use an shutdown relay but, I can't find a schematic that shows how it's connected.
