Trans cooler blown?
Old Oct 11, 2009 | 09:23 AM
  #21
lilreddakota's Avatar
lilreddakota
It's Alive!!! Found a NEW radiator on E-bay for $56 shipped to my door!! Swapped it out about a month and a half or two months ago and all is good so far.
If the the OEM radiator was built like this one there wouldn't be an issue with these. The replacement has a brass cooler with the hose nipples as part of it, This unit is installed inside the tank same as OEM but it is threaded externally for a nut to cooler inside radiator. The OEM has a hose nipple threading into the cooler inside the tank. A small leak here could be just inside radiator and mix coolant and trans fliud. The replacement setup would just be a coolant leak outside the radiator if the nut loosened or a trans fluid leak if the hose clamp loosened. The only way you would have fluid mixing is if the cooler cracked. Should have taken pictures when I was matching them up to make sure it was correct radiator. I might see if I can get under it and get some. I still have the old one to get pics of.
Old Oct 25, 2009 | 11:28 PM
  #22
francois74's Avatar
francois74
Default Bad Radiator
My 2004 sxt radiator split and I had trans fluid mixing in the coolant. The car ran for about 3 miles when radiator gave way. I had it tow to my house and put in the new Radiator. I then drove it 10 miles to the dealer and had the transmission and coolant system flushed. I replaced the transmission fluid with the MOPAR brand. Trans been fine and that was about 10,000 miles ago.
Old Oct 27, 2009 | 11:26 AM
  #23
mjs182004's Avatar
mjs182004
I'm seeing a trend of this sort of problem. 1 by 1 every neon is going to have this issue.
Old Dec 10, 2009 | 12:12 AM
  #24
yellow_66's Avatar
yellow_66
140K on mine and boom trans fluid in the coolant, so ive flushed it and replaced the radiator. Seems to be shifting fine. woohoo
Old Dec 13, 2009 | 12:39 PM
  #25
mjs182004's Avatar
mjs182004
yellow 66, you will be having your tranny rebuilt soon in the near future.
Old Aug 18, 2013 | 02:06 AM
  #26
turbo talon dl 94's Avatar
turbo talon dl 94
Default Stock trans cooler failure.
Deleted.
