Door fuse problem???
Old May 17, 2009 | 08:22 PM
tr10av's Avatar
tr10av
Default Door fuse problem???
I searched for an answer and this describes my problem perfectly:
2000 Dodge Neon The odometer flashes and says door then fuse and then the mileage it continues flashing in sequence The mileage stays lit up even when all the power is shut off?
Some of the answers given were:
Answer
I came across your problem while searching for the identical situation in my son's car. The only difference was that his dome light also stayed on. Not finding an answer on the Web, he took it to a mechanic who played around with the switches on the doors. After doing something to adjust the switch on one of the rear doors, the problem stopped. My son said that it took only minutes, and the mechanic didn't even charge him for the fix.
Answer
I had the same problem with my 2000 dodge neon. The fuses were all good, under the dash and under the hood. The interior light acts as a fuse for the door system, therefor door fuse flashes, so I checked the interior light bulb, it was good. Then I began to trace the interior wiring, it went to the roof interiors back driver side and then down beside the driver side back seat, if that makes any sence. You can take the plastic off were the interior lining ends and there is a connecting with a red mulex type connector. If the two halves are unplugged plug them up and your good to go. Hope this makes sence and works.
Answer
i have the same problem for the last 4 months i learened that you have to replace the door stopper
If someone has had this problem in the past and fixed it could you go into a little more detail on exactly how to fix it? Thanks alot.
Old May 17, 2009 | 11:08 PM
smallblockfreak's Avatar
smallblockfreak
glad you found your answer when my door thing messed up i didn't have the fuse thing and all i did was cut the wires to that door so my dome light only comes on when three of the doors are open not the fourth which is no big deal to me.
Old May 18, 2009 | 11:58 AM
tr10av's Avatar
tr10av
What door did you have to cut? The back seat on the driver's side?
I found the answer but I need a little more clarification on exactly what I'm looking for like what is the door stopper, where is it, and how much/how hard it is to replace?
And where exactly is this red mulex connector? Is it on the drivers side back seat door pillar?
Old May 18, 2009 | 12:17 PM
smallblockfreak
yes it was the driverside back door that messed up on mine.
Old May 18, 2009 | 02:19 PM
darthroush's Avatar
darthroush
Section Moderator
Mine flashed fuse when I was missing a ground in the engine bay. Fixed the ground (reattached it actually, lol, oops on my part) and it was good to go.
Old May 18, 2009 | 02:32 PM
tr10av's Avatar
tr10av
I think mine is spefically the door fuse though because above the odometer is says door and that never goes off or changes
Old May 19, 2009 | 02:34 AM
darthroush's Avatar
darthroush
Section Moderator
Yeah, probably then. Just saying it can be more than the door I suppose.
Old May 20, 2009 | 06:03 PM
tr10av's Avatar
tr10av
Fixed It: Ended up that the passenger side door stop thing wasn't working. Just took it out replaced the dome light and problem solved.
Old May 22, 2009 | 02:03 PM
darthroush's Avatar
darthroush
Section Moderator
Congrats on the fix!
Old May 23, 2009 | 05:51 AM
tr10av's Avatar
tr10av
Thanks, glad it was something relatively simple and cheap. And not some annoying thing I was going to be stuck with. Now if I can just all the speakers working.
