How do I remove window crank??
Old Jun 17, 2009 | 01:31 PM
tr10av's Avatar
tr10av
Default How do I remove window crank??
I'm trying to get the door panels out to install some new speakers but I can't get the manual window crank off. I know there's a special tool for it but I have no idea where to find one. I've tried using a screwdriver and other stuf but I can't get it off. Does anyone know how I can get this off without breaking it???
Old Jun 17, 2009 | 02:39 PM
j_son600's Avatar
j_son600
Slide a rag between the crank and door panel, should catch the clip and pop it out for you.
Old Jun 17, 2009 | 02:54 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
they make a little tool at any local parts store, only maybe ten dollars.... saves alot of time and agrivation, along with will not break the handle or panel
Old Jun 17, 2009 | 03:53 PM
tr10av's Avatar
tr10av
I went to Advance Auto parts to see if they had one and the person said he'd never heard of it. Do you have a link or something?
Old Jun 17, 2009 | 03:54 PM
tr10av's Avatar
tr10av
So just for clarification the only thing I need to do is pull out the retaining clip right? I'm not squeezing it together, pushing it in, or anything like that correct?
EDIT:
Just found this:
http://www.carstereohelp.com/stereor...ndowCrankR.htm gonna go check and see if I can get it now.
Old Jun 17, 2009 | 06:21 PM
tr10av's Avatar
tr10av
Got it with the rag. Thanks for the tip.
Old Jun 18, 2009 | 09:05 AM
dtjackten's Avatar
dtjackten
u must of talked to a complete retard at advance, i would bet u they r in stock for about ten dollars.... glad u got it though
Old Jun 18, 2009 | 04:40 PM
KARR's Avatar
KARR
From: In a Lucid Dream. But now I want my life back.
I never tried it with a rag. Do you pull the rag side to side? (left to right)
Old Jun 18, 2009 | 10:09 PM
tr10av's Avatar
tr10av
Basically. If you go to that link I posted it shows it pretty well. All you have to do is pull the crank out a little so you can see where the clip is and then put the rag where one of the ends are and it will catch and pop it right off. 20 seconds and you're done.
