IAC- id clean it if i could FIND it...
Old Jun 20, 2009 | 11:56 AM
kabuk1's Avatar
kabuk1
Default IAC- id clean it if i could FIND it...
could someone tell me where the IAC is on my 05? i wanna clean but i cant find it to save my life. im used to working on my 99 i guess. i know what an IAC looks like & couldnt find anything like it on this one. i wanna clean it & see if it clears up my rough idle. as soon as my car warms up the idle rpms drop to about 650-700 & it stumbles a bit & runs kinda rough.
Old Jun 20, 2009 | 01:08 PM
darthroush's Avatar
darthroush
Section Moderator
On the side of the throttle body, right after the air filter box.
Old Jun 20, 2009 | 02:07 PM
kabuk1's Avatar
kabuk1
Which side? The only sensor I can find on the side is the TPS. I thought it was the silver part on top(circled) but when I got it off, it didn't look anything like an IAC & I was scared to mess with it.
Old Jun 21, 2009 | 02:28 AM
darthroush's Avatar
darthroush
Section Moderator
That's it. The IAC on my Neon looked just like every other one I've seen. Are you sure what you think the IAC is, is actually that? The IAC isn't a sensor per se, like the TPS or CPK, etc...
Old Jun 21, 2009 | 08:37 AM
kabuk1's Avatar
kabuk1
yeah, its the idle air control valve, the part that fubars your idle if its dirty. mine looks so wierd. the iac on my 99 looked like a little black bullet, this is some wierd silver thing w/a black gasket on the inside. ack im so confused.
Old Dec 21, 2009 | 03:05 PM
bfons's Avatar
bfons
Hey guys,
My idle issues have prompted me to look at this. How do you clean this booger?
TIA
Old Dec 22, 2009 | 10:10 PM
darthroush's Avatar
darthroush
Section Moderator
I used a lot of SeaFoam spray. I've used brake cleaner too. I *think* anything that will remove carbon deposits will be fine, but I'm not 100% sure on that.
Old Dec 23, 2009 | 04:44 AM
mjs182004's Avatar
mjs182004
Old Dec 23, 2009 | 02:23 PM
darthroush's Avatar
darthroush
Section Moderator
That is incorrect. The TPS (Throttle Position Sensor; no need for the extra "sensor" at the end) and IAC (Idle Air Control) Valve are labeled backwards in that picture.
Old Jun 2, 2014 | 07:36 PM
Bleed_gold's Avatar
Bleed_gold
Default Can anyone show how to take it off!!
My car keeps bucking and jerking. Drop of acceleration. Power surging, bad idle. Does anyone have video I can see to clean the IAC or possibly change the TPS!??!!! Working on a budget and can't afford shop price for something I could do myself!! Please help '05 neon
