Malfunction indicator light
Old Jun 30, 2009 | 09:25 PM
habfan1973's Avatar
habfan1973
Default Malfunction indicator light
Have a 2000 Neon and my mil light has come on. I was stopped at a stop sign when I felt the car jerk. It did this a couple of times then stopped. I was then starting to pick up speed when the engine became sluggish and seemed to work better when I let off the gas. About 50km later the MIL light came on and started to flash when the engine would become sluggish and would remain on when it was not sluggish. Any ideas what might be causing this? Thought maybe something to do with the catalytic converter? Any help would be great.
Old Jun 30, 2009 | 09:45 PM
darthroush's Avatar
darthroush
Section Moderator
Get the code.
Old Jul 1, 2009 | 01:49 PM
habfan1973's Avatar
habfan1973
error code p0302 cylinder #2 miss fire detected in cylinder 2
any thoughts on what this could be?
Old Jul 1, 2009 | 02:10 PM
darthroush's Avatar
darthroush
Section Moderator
Could be a bad plug, wire, coil pack, or injector. Most likely, in that order from likeliness to happen to not. I'd start checking with the plug and work your down the list.
Old Jul 1, 2009 | 05:45 PM
OhNo2.0's Avatar
OhNo2.0
I like easy fixes like this.
Old Jul 3, 2009 | 09:32 PM
habfan1973's Avatar
habfan1973
yes it was the plug...easy fix but I went ahead and replaced the wires and the coil anyway. tks
Old Jul 4, 2009 | 01:59 AM
darthroush's Avatar
darthroush
Section Moderator
NP, enjoy the running car again!
