Want Head?
Just had some heads cleaned, have more to get done. Did some mild porting here and there to open things up on the exhaust side.
All head have been cleaned, mildly ported on the exhaust side, come with egr block off on cylinder head, polished stock valves, and new vavle seals. Starting at for first 10 buyers. $220 shipped in the US.
What a let down...j/k
How did you polish those valves? They look good. It also looks like you blasted the manifold faces? IS that a normal procedure?
Also, how did you finish the other mating surfaces, the valve cover surface looks like it was hand sanded? What about the bottom end?
It looks like you know what you are doing, I'm going to be digging into my spare motor any day now and need tips when it comes to cleaning everything up.
Everything from blasting media used to polishing compounds...
