Need help with 2001 ES
Old Aug 26, 2009 | 04:07 PM
abk1234's Avatar
abk1234
Exclamation Need help with 2001 ES
i just bought my ES.and realize that my ES takes up about 15-18 MPG which is not normal since the car is stock. after i look it up and it should be about 29-38 MPG.
does anybody know what might happened to the car and cause this problem
Old Aug 26, 2009 | 05:19 PM
N3ON's Avatar
N3ON
change your o2 sensor.its a main cause for loss of mpg if your car runs fine.if the air filter is good and the spark plugs then this is your problem.if you have a bad o2 sensor it wont flip the cel which sucks but try the upper one located right behind your exhaust manifold.
http://www.autozone.com/autozone/cat...ll&totalPages=[I@b53827&currentPage=1&vehicleNValue=&navValue=161 00117&parentId=61-0&fromString=&fromWhere=null&filterByKeyWord=&cate goryNValue=&categoryDisplayName=Exhaust&_requestid =1730612
^^^these prices are outrageous...i thought you can get a universal one for like 40 bucks...
either way it will increase your mpg..GOOD LUCK.......
Old Aug 26, 2009 | 07:20 PM
abk1234's Avatar
abk1234
should the engine light shown when the o2 sensor go bad?
Old Aug 26, 2009 | 07:55 PM
Pablodragon's Avatar
Pablodragon
No, it won't... that's what he mean't when he said " if you have a bad o2 sensor it won't flip the CEL" that means it won't trigger the Check Engine Light (CEL)
Old Aug 26, 2009 | 11:08 PM
abk1234's Avatar
abk1234
how many O2 sensor does 2001 neon es has and where it located.
Old Aug 27, 2009 | 04:11 AM
N3ON's Avatar
N3ON
it has an "upper" one and a "lower" one.theres one before and i think after the cat.the upper one is right behind the exhaust manifold on the back side of the engine.make sure the car is warm so you can get the o2 bolt off but you dont want it too hot cause you'll burn your hand trying to get it off
correct me if im wrong about the second one
