water pump leaking... need advise!!!
Old Sep 9, 2009 | 09:07 PM
christian_2k2's Avatar
christian_2k2
Default water pump leaking... need advise!!!
my water pump is going out (starting to leak coolant) so i'm about to tackle this project. i have a 2004 neon sxt with 74000 miles. i know you should replace the timing belt when you change the water pump. i was thinking of going with gates high performance timing belt. what brand water pump should i use? what else do i need to replace? and since everything is going to be torn apart should i go head and install aem cam gears, underdrive pulley? or is this just a waste of money?
Old Sep 9, 2009 | 09:11 PM
goldringlee's Avatar
goldringlee
Thanks for your sharing. Thanks for sharing this useful information. It's great.
calcul financement courtier | simulation pret immobilier | taux credit de france simulation crédit immobilier sera le total du prêt calcul financement courtier | simulation pret immobilier | taux credit de france
