Alarm/remote start/ keyless entry?
Old Oct 27, 2009 | 07:43 PM
neisg1's Avatar
neisg1
Originally Posted by darthroush
There are transponder bypasses that do not require a key to be left in the car. However, needing two keys to program them may be a necessity. That I am unsure of.
That's right below is a quote from the above link.
"Transponder Bypass: RF override via induction w/ loop antenna (transponder incl. NO KEY required) ONE TIME PROGRAM ONLY. 2 keys required for programming this module"
Old Oct 28, 2009 | 06:37 PM
darthroush's Avatar
darthroush
Section Moderator
Huh, well that sucks. Damn key will cost 1/2 the price of the remote start!
Old Oct 28, 2009 | 07:50 PM
cwebbatya's Avatar
cwebbatya
I have Alpine everything. I hooked it up myself with the help of a member on here. Look him up, he knows what hes talking about. his username is "badvenge"
Old Oct 29, 2009 | 08:11 PM
KARR's Avatar
KARR
From: In a Lucid Dream. But now I want my life back.
I want remote start with the alarm but I never got it since I dont have power locks. I was looking at the Bulldog systems.
Old Oct 30, 2009 | 12:16 AM
Franklinnn's Avatar
Franklinnn
how hard or is it possible to make it so i have power locks?
Old Oct 30, 2009 | 01:03 AM
neisg1's Avatar
neisg1
I’m assuming you want to add power locks to a non-factory equipped Neon. The lock actuators are built into the door latches on Neon’s. So you could change the latches out to power ones but, I believe you would have to run all new wiring. You can also buy after market actuator kits but once again you have to run all the wiring. This is another changeover that would probably work best if you had a donor car for all the parts.
Old Oct 30, 2009 | 02:02 AM
Franklinnn's Avatar
Franklinnn
Hmm thanks for the help! sounds like a big pain, but guess ill have to keep opening my GF's door and be a gent ;D
