a/c issues
Old Nov 3, 2009 | 02:33 PM
4flower's Avatar
4flower
Default a/c issues
My a/c just stopped working one day...it blew cold at lunchtime then after work all it did was blow hot air...any ideas????
Old Nov 4, 2009 | 12:00 PM
mjs182004's Avatar
mjs182004
might be the a/c relay
Old Nov 4, 2009 | 10:25 PM
neisg1's Avatar
neisg1
Have a look at the compressor pulley with the A/C set to max to see if the compressor is engaging. If it is engaging, then it’s a problem with the actual A/C system as possibly low on refrigerant or bad compressor
If it does not run it could be:
1)Fuse, relay, switch, compressor clutch or bad wiring.
2)Bad high or low pressure switch is not allowing the compressor to run.
3)So low on refrigerant that the low pressure switch is not allowing the compressor to run.
Old Nov 6, 2009 | 02:02 PM
4flower's Avatar
4flower
Thanks for all the help...I will check and see what happens...thanks again
