speedometer?
Old Nov 6, 2009 | 05:14 PM
4flower's Avatar
4flower
Default speedometer?
Anyone know what would make your speedometer gauge bounce around? I can still drive the car fine but the speedometer gauge bounces around....let me know if you know what it might be...thanks
Old Nov 8, 2009 | 02:18 PM
Franklinnn's Avatar
Franklinnn
The whole cluster or just the needles?
does it look like this:
http://www.youtube.com/watch?v=MDUweDg0Mbc
if so, you will need to dismantle the cluster and replace the motor for the speedometer needle.
Old Nov 8, 2009 | 05:59 PM
LowSlowNeon's Avatar
LowSlowNeon
My speedometer skipped around different then the video posted above me. I'm not really sure what the problem was, but I made the dealer fix it when the car was under warranty. They ended up just replacing the entire cluster with a new one. Since it has been replaced I haven't had any problems.
Old Nov 9, 2009 | 01:30 AM
darthroush's Avatar
darthroush
Section Moderator
That is what gauges do when the battery is on it's way out. If it is "bobbing" while you are driving, it could be the speedo cable or gear.
Old Nov 16, 2009 | 02:25 AM
mjs182004's Avatar
mjs182004
mine did that, ended up being the whole cluster. it took the dealer a month to figure it out, and $500 bucks later. The needle also would like to stick around 70mph sometimes.
