2002 Neon motor mounts + other ?'s
Old Nov 11, 2009 | 09:43 PM
midlight21's Avatar
midlight21
Default 2002 Neon motor mounts + other ?'s
Okay....I had the motor mounts replaced 6 months ago....and now its back in the shop getting new motor mounts again. Thankfully they are under warranty but seriously....6 months and I have to have them replaced again? Anyone know what would cause that to happen?
AC unit.... If I drive for 45 min to an hour (normal commute time to work), the blower stops blowing like it should. It blows a tiny bit and I can tell the air is still cold. Blower going out?
Pulling to the left... I've had the tires replaced, rotated, aligned, had the bushings and the tie rods checked...darn thing still pulls to the left. Any ideas?
Old Nov 12, 2009 | 03:00 AM
darthroush's Avatar
darthroush
Section Moderator
When you say motor mounts...do you mean the single, actual motor mount or the two torque strut mounts?
Old Nov 12, 2009 | 05:38 AM
midlight21's Avatar
midlight21
I mean all of them including the transmission mount.
Old Nov 12, 2009 | 02:27 PM
darthroush's Avatar
darthroush
Section Moderator
How do you drive? How are the roads? Are they installing the torque strut mounts in properly and aligning them? That would take a lot of work from something to get all four mounts to go out in 6 months...
