2003 Dodge Neon SXT 2.0
Old Nov 25, 2009 | 04:03 PM
DorianM's Avatar
DorianM
Default 2003 Dodge Neon SXT 2.0
About a week ago I was leaving work, and i started and the light came on, and then i started goiSn my car was shaking hard, and after few second it shuts down. I went to AutoZone and tested the car and i got po132(oxygen sensor hight voltage), po440, po441(EVAP SYSTEM INCORRECT PURGE FLOW). The po132 heated oxygen sensor bank 1 sensor 1 how can this be, I changed the oxygen sensor less than 2 weeks ago. The autozone told me to check the canister, or solenoid for po440, po441,. WHAT DO YOU GUYS RECOMMEND?
Old Nov 28, 2009 | 04:00 AM
darthroush's Avatar
darthroush
Section Moderator
Check the canister and the lines for cracks, etc.
Old Nov 30, 2009 | 04:53 PM
DorianM's Avatar
DorianM
Where would that be?
Old Dec 1, 2009 | 01:40 AM
darthroush's Avatar
darthroush
Section Moderator
Vapor canister is on the right side of the car, in front of the back wheel under the body. The hoses on there, mainly the large one on the left, crack and will cause a leak.
Old Dec 1, 2009 | 04:17 PM
DorianM's Avatar
DorianM
I have checked it about 50 times and looks good, the lines are good,
Old Dec 1, 2009 | 08:19 PM
darthroush's Avatar
darthroush
Section Moderator
Old Dec 2, 2009 | 12:54 PM
deranged's Avatar
deranged
Where do you get that stuff! I need to know!
Old Dec 9, 2009 | 01:06 PM
joeandcatherine's Avatar
joeandcatherine
i have an '03 dodge neon sxt. i need to replace my oil sending unit or oil pressure switch or oil pressure sending unit, whatever you want to call it. i know where it is (passenger side, rear of engine. tucked right below the manifold) and i've read that to get to it, it's best from underneath the car. do i have to remove any parts to get to it? or is there an easier way. i just don't know where to start. can someone help?
Old Dec 13, 2009 | 03:41 AM
darthroush's Avatar
darthroush
Section Moderator
You should start your own thread for your own vehicle issue
Old Dec 31, 2009 | 10:35 PM
DorianM's Avatar
DorianM
thanks for the help.
