ignition cylinder change
Old Jan 4, 2010 | 07:39 PM
preston75052's Avatar
preston75052
Default ignition cylinder change
hey everybody, im new to this site.my name is preston!
i have a 2000 dodge neon and my ignition cylinder went out so i have to change it! from what i see,there is 2 star bolts that are holding it! well these bolts have a round piece of metal in them like a particular star bolt tool slides in the bolt to turn them! anybody have any idea what tool to use?
Old Jan 4, 2010 | 08:27 PM
leprechaun1874's Avatar
leprechaun1874
sounds like you need a security torx bit. looks like a regular bit but is hollow in the center.
Old Jan 4, 2010 | 11:37 PM
preston75052
u know your absolutely rite! i went to autozone and picked one up
thanks bro! i will let ya'll know what the outcome is when im done! thanks!
Old Jan 6, 2010 | 05:52 PM
preston75052
ok here is the outcome! tore apart the the ignition,noticed a different problem! turns out its my ignition switch and the part that broke off in there, this piece is in between the ignition cylinder lock and the ignition switch, that is what broke off in the switch, and the screwed up thing is,u cant buy that separate,u have to buy the whole steering columm bc dodge dealer considers it part of the steering columm! junkyards wouldn't even let u pull just that piece! steering columm from a dealership 350:00 to your personal machanic 200.00 used parts and labor!
this piece doesn't even have a name, but its round shape with a white casing over it,no more then 3 inches long! it reminds me of a crankshaft when i look at it!
