Part needed
Old Jan 17, 2010 | 07:04 PM
crash05's Avatar
crash05
Exclamation Part needed
I need 2 headlight bulb retaining ring for 2005 dodge neon 9007. i have tryed searching on google but unable to locate them. trying to stay away from dodge dealer but i will go if i can not find any.
Old Jan 19, 2010 | 07:57 PM
BroodRed's Avatar
BroodRed
Try going to your local Pepboys. The one near me had the retainers for about $6.
Old Jan 19, 2010 | 11:31 PM
lherrera1228's Avatar
lherrera1228
Question Bad Battery Wires and Vibration
I own a 05 Neon SXT with 115K miles. The engine started vibrating a lot. I installed new spark plugs, Spark plug wires, Coil, Fresh Oil Change and filter. I run this sucker in Premium Gasoline since I bought it 30 months ago with 50k miles. I drive about 100 miles to work back and forward. It still runs 90-95 mph. The help I need is where do I get Battery Wires since the plastic is coming off of mine and what other ideas you guys have about the damm vibration whole car shakes bad. I changed 2 motor mounts as well top pass and lower middle. Due to bad weather in houston I ran the car thru high water as well you think that mess the car up this happened at about 80k miles.
Old Jan 20, 2010 | 02:55 AM
darthroush's Avatar
darthroush
Section Moderator
Again, You already started a thread about it, nor does it have anything to do with what this thread is about. Stick to yours.
