Where is the crankshaft sensor
Old Jan 25, 2010 | 06:27 PM
canfidacus's Avatar
canfidacus
Default Where is the crankshaft sensor
Hello, i have a 2003 dodge sx 2.0 took it to get scanned and i was told it was crankshaft sensor, they told me it was about 80$ to replace, Where is the sensor located on the engine and what is involved in changing it myself, is there any pics or video's of where and how to change it, Thank you
Old Jan 25, 2010 | 07:18 PM
02sxtneon's Avatar
02sxtneon
If I am right the sensor should be on the right side next the battery and is real easy to change
Old Jan 26, 2010 | 07:59 PM
Pablodragon's Avatar
Pablodragon
the CAMSHAFT sensor is the one near the top of the motor, right by the battery...that one is easy, but I'm not sure where the CRANKSHAFT sensor is....
Old Feb 2, 2010 | 11:23 PM
The Black Stig's Avatar
The Black Stig
Straight from the Haynes manual.
1. Disconnect the negative battery cable.
2. Raise the front of the vehicle and place it on jacksatnds.
3. On 2003 and latter models, remove the structural collar.(i have no clue what that is is say reference oil pan removal and installation I'm assuming some type of skid pad or brace.)
4.Disconnect the ckp sensor electrical connector.
5. Remove the CKP sensor retaining bolt.
Seems easy to me, I will try to add the pics in a minute.
Old Feb 2, 2010 | 11:30 PM
The Black Stig
Pic's
Old Feb 5, 2010 | 06:50 PM
canfidacus's Avatar
canfidacus
Thanks for all the info everyone, the pic helped out alot and with the sencor in hand i figured it out and saved myself 80$...again thank you.
