03 neon r/t please help
Old Jan 28, 2010 | 11:19 AM
chinaa1's Avatar
chinaa1
Question 03 neon r/t please help
hello guys I'm real happy to be a new member. I have a 03 neon r/t 35,000 k. while driving it suddenly started missing on the number 1 and 2 cylinders. the system flashed no codes, it has fire from the coils, good compression. I replaced the plugs and it made no difference, got the injectors clean and switch them from 3and 4,no difference. I am really lost can someone please help. thank you
Old Jan 28, 2010 | 01:57 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Neon section,
FF
Old Jan 29, 2010 | 01:38 PM
tooslow's Avatar
tooslow
how do you know it cyl 1 and 2 if there is no code. the spark is a wasted spark system 1&4 fire together 2&3 one of those two it could be the coil or cam sensor. but if you are sure it ain't spark or fuel. then maybe it is timing related maybe it jumped a tooth but
Old Jan 29, 2010 | 11:06 PM
contagious19's Avatar
contagious19
also check the wires but i had more coils go bad then wires so check that, and too slow has a point. only way to know which cylinders it is if there are no codes?
