WTH hell is the PCM/ECU fuse?
Old Feb 9, 2010 | 02:27 PM
The Black Stig's Avatar
The Black Stig
Default WTH hell is the PCM/ECU fuse?
WTH hell is the PCM/ECU fuse? the one that one would pull to rest the a CEL
Old Feb 9, 2010 | 04:06 PM
srtgtr34's Avatar
srtgtr34
Just unplug the battery and leave it unplugged for a bit.
Old Feb 9, 2010 | 05:04 PM
The Black Stig
I redid the wiring which include bat terminals and they look pretty but are much harder to get off.... but thanks anyway....
Old Feb 9, 2010 | 09:58 PM
darthroush's Avatar
darthroush
Section Moderator
Pull the fuel pump relay. I got a damn engine light for an EVAP problem, again, today. Going to check everything and then pull the relay. Weee.
Old Feb 9, 2010 | 10:57 PM
The Black Stig
$20 on your gas cap being the cause
Old Feb 9, 2010 | 11:33 PM
darthroush's Avatar
darthroush
Section Moderator
I've had an EVAP code before and it was a charcoal canister line cracked to all hell. The code is for the EVAP Purge Solenoid/NVLD. It says small leak test has passed in order to get this code. I had the small leak code before --> that line. I'd be very suprised if it was the gas cap as I always click it at least three times and it came on ~200+ miles into the tank of gas. I'm not ruling it out, but I'm just saying. I've had two other codes before, reset the PCM, and never seen them again. Maybe I'll just try that first before stressing myself out trying to find it.
Old Feb 11, 2010 | 01:16 PM
tooslow's Avatar
tooslow
fuel pump fuse works it will reset the ecu
