02 neon wont start
Old Feb 21, 2010 | 06:22 AM
mxwarrior02's Avatar
mxwarrior02
Default 02 neon wont start
well i got a 02 neon with an auto trans and it was running fine then the next morning i went to start it and nothing. had the starter checked and it was fine. new batt and terminals on bot pos and neg and still nothing. there is A code in the gauge cluster p-1684 which is the batt disconect i know but how do you get rid of it or what can i look for or?
Old Feb 21, 2010 | 03:52 PM
darthroush's Avatar
darthroush
Section Moderator
Pull the fuel pump relay in the engine bay for a few minutes. It will clear codes without having to disconnect that battery. That, or after the car is started like 50 times again, the code will self clear. It's a dumb code. No CEL from it, just pick what you want to do.
Old Feb 23, 2010 | 02:06 PM
mjs182004's Avatar
mjs182004
I had the same thing happen to mine. it ended up being one of the relays. can't remember which though.
Old Mar 24, 2010 | 01:53 AM
Reura's Avatar
Reura
Happened to me, but it wouldn't even attempt to crank over. Turned out to be the sentry key system (the anti-theft device that won't allow the car to be started using a key with out a programed chip). It malfunctioned and they replaced it under the 80,000 mile warranty.
