Brakes sticking!
Old Mar 5, 2010 | 03:35 PM
sadieportman's Avatar
sadieportman
Default Brakes sticking!
I have a '02 Dodge Neon and whenever I brake the rear passenger side wheel seems to get lock up. I push on the gas and it will eventually let go but I know this isn't good for my engine. Sometimes if I press all the way down when braking, the locking is avoided. Though it's hard when making a left turn to push all the way down. HELP! Could this be the caliper?
Old Mar 5, 2010 | 03:45 PM
Tizzy1's Avatar
Tizzy1
yes, caliper or caliper slide.
Old Mar 5, 2010 | 05:10 PM
Midnight Runner's Avatar
Midnight Runner
Welcome to D.Forum. You mite ask the guys on the neon forum. They can help you.
Old Mar 5, 2010 | 05:35 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome ot the site. I will move this thread to the second generation Neon section,
FF
Old Mar 6, 2010 | 08:19 PM
sadieportman
Default Thanks!
Thank you everyone for your help. I made it home on Friday but almost immediately I started leaking what I assume was brake fluid (it was a red rusty color). I think a line of some sort burst. I am taking her in on Mon.
Old Mar 7, 2010 | 11:26 AM
Twkdout066's Avatar
Twkdout066
Do you have drums or rotors on your rear wheels. It sounds like yuou have a bad brake cylinder and when you pulled up on the E-brake they automatically adjusted wrong. My suggestion is if you havew drums take it somewhere to have it fixed, they are a pain to work with. (rotors also have the same equipment on the rear brakes except behind the rotor.) either way it sounds like a good brake job will fix you problem.
Old Mar 7, 2010 | 02:02 PM
darthroush's Avatar
darthroush
Section Moderator
A rusty red color? Brake fluid should be clear, and then it will turn black as it gets old.
Old Mar 7, 2010 | 06:53 PM
Twkdout066's Avatar
Twkdout066
Unless its cleaning the rust off the drums/rotors.
Old Mar 8, 2010 | 02:22 AM
darthroush's Avatar
darthroush
Section Moderator
Yeah, good point.
Old Mar 9, 2010 | 05:52 PM
sadieportman
It looks like it wasn't my brakes at all! For some reason my radiator had crack in it causing my transmission fluid to mix with my coolant. I was lucky to get it in when I did. My transmission was salvaged!
