Check Engine Light
Old Mar 12, 2010 | 09:12 PM
00neonlx's Avatar
00neonlx
Default Check Engine Light
I read on here some where how to do a cold air intake, they said something aboout a restricter and to just add a cone. I took the top off and added a k&n filter, and left the top off. I couldnt find a restrictor idk if i wasnt looking in the right place, and also it threw the check engine light I am not sure if it was because of the air intake sensor that is on the little tube that goes down into the fender or what
Old Mar 13, 2010 | 01:44 AM
darthroush's Avatar
darthroush
Section Moderator
You shouldn't get a code just from changing the air filter, nor should you have to find a "restrictor" for a direct replacement filter. As for leaving the lid off and removing the sensor, put them both back. No reason to take them off.
Old Mar 13, 2010 | 11:43 PM
00neonlx's Avatar
00neonlx
i got the check engine light to go out, i put the cover back on, and eventually it went out, then took the cover back off and it hasnt come back on since, Without the cover the cold air intake dosent have much sound, and i LOVE the sound,
Old Mar 14, 2010 | 04:49 AM
darthroush's Avatar
darthroush
Section Moderator
Changing an air filter doesn't make it a cold air intake. The factory set-up however, is a cold air intake by style/design. Removing the inlet tube and taking the cover off has effectively made it into a warm air intake if anything.
