05 Sx 2.0 firing misses??
Old Mar 23, 2010 | 01:56 PM
hobbsao's Avatar
hobbsao
Question 05 Sx 2.0 firing misses??
could anyone guide me on the right direction?
my vehicle is missing when i stop at lights with brake on the engine skips a beat here and there, also on hwy i can see rpm guage move a bit too
i wonder if it isnt the coil...any ideas??
thanks in advance.
Rob
Old Mar 23, 2010 | 09:11 PM
AnthemBassMan's Avatar
AnthemBassMan
-Check your spark plugs. I just changed mine today. I was starting to experience the same things you are. When I pulled the plugs, at first they looked like they were burning clean. But then I noticed the gaps. Three of the plugs had gaps that were worn between .050" and .060". Not too good considering they are supposed to be .035". I also picked up a new set of plug wires since the car has 70k on it now. I just got a set of Autolite Professional Series wires at Advance Auto for $29 and change including tax. You should be able to get by spending about $40 on plugs and wires combined.
L8R,
Matt
Old Mar 26, 2010 | 02:17 PM
hobbsao's Avatar
hobbsao
thanks for the post, I did change plugs, but still had the same problem.
I just ran some Duralube injector cleaner through it and it seems to be getting better.
Old Mar 26, 2010 | 07:08 PM
AnthemBassMan
-Glad you found it. I did the injector cleaner first with no change. But I was kind of shocked that the NGK plugs widened that bad. I used to run only NGK and Bosch plugs when I ran dirtbikes and they never let me down. Now both brands have. So back to stock Champions that I hated back in my dirtbike days.
L8R,
Matt
