Help with My Neon RACE CAR No Start 00 to a 01 RT
Old Apr 27, 2010 | 12:17 AM
cj_lavair's Avatar
cj_lavair
Default Help with My Neon RACE CAR No Start 00 to a 01 RT
ok it dose not crank..by the key.i ck clutch switch,ck the fuses...ck the ground...strarter....pcm.....i have chang all them...when u turn key all the dash lights up..and u can here the fule pump running...
it was a 2000 neon..i put in a 2001 rt motor and tran.......if i put the 00 ECU in it..it will run but like junk...
to day i ck and got spark... so i jump the start and it turn over that way.... so then i put gas it the TB and she ran...
i went and got the Elec Cont Unit (ECU), w/o eng immobilizer; (black ignition key), MT, R/T, ACR
IS Dash Wiring Harness Dodge Neon for a 00 to a 01 diffent?? it all hook up right
WHAT SHOULD I DO NEXT??? HELP ITS MY RACE CAR AND GOT TO BE READY THIS SATURDAY
Old Apr 27, 2010 | 11:25 PM
Captansavaho's Avatar
Captansavaho
maybe the key needs to be matched up with the pcm? like programmed?
Old Apr 28, 2010 | 12:09 AM
cj_lavair's Avatar
cj_lavair
dodge said if i got the ECU), w/o eng immobilizer; (black ignition key)
that it would work...now iam told to get the hole wireing ever thing..
Old Sep 3, 2010 | 03:32 AM
neonftw87's Avatar
neonftw87
i hate the fact that you cant type sentences, cant understand a dam thing you say
Old Sep 5, 2010 | 02:45 AM
NHARINTON's Avatar
NHARINTON
First the RT has a diffrent head then any lower neon so your fuel/air/timing will be off. You need a PCM from the motor you bought to properly swap it.... or get megasquirt (but thats a whole new game)
If you really want help, retype all your above posts with good, normal English and explain in detail EVERYTHING you have done and EVERYTHING it is and is not doing.
then we can help! I am building a track car right now too so I feel your pain.
