camshaft position sensor help
Old May 13, 2005 | 02:27 PM
neonrider's Avatar
neonrider
Default camshaft position sensor help
I have an neonle 2002 and the checking light comes on when the car stumbles and almost dies. I got the codes p0340 and p0420 and they come on at the exact time. What is the porblem(s) and how can I fix them?
Old May 15, 2005 | 04:42 AM
ewetho's Avatar
ewetho
Default RE: camshaft position sensor help
remember to trouble shoot the first listed code as this is the first code. Even if you get both the first one set will be listed first and this one should be corrected first. Note the second but trouble soot the first one first. Would hate to spend money on parts that were OK. If it is still under warraty then I would suggest Dodge first.
Old May 17, 2005 | 04:50 AM
mechengineer201's Avatar
mechengineer201
p0340 is no cam signal at the pcm - no fuel sync
p0430 is 1/1 catalytic converter efficiency - efficiency below the reqired level
The cam sensor has an IC in it which may have **** the bed...
