04' Neon Missing When A/C is running
Old Jun 25, 2010 | 08:12 AM
cec311's Avatar
cec311
Default 04' Neon Missing When A/C is running
Have an 04' Neon 2.0. If you crank it with the A/C on it will spit and sputter while it is idling. When you stop at a stoplight it will miss and sputter and occasionally while driving. It runs perfect with the air turned off. I've already changed plugs and wires, but am stumped at what it is doing.
Any suggestions would be appreciated!
Old Jun 25, 2010 | 08:41 PM
LowSlowNeon's Avatar
LowSlowNeon
Yeah, not sure what is causing that. When the air is on in mine you can definitely feel when the a/c compressor is on because there is a definite drop in acceleration. But mine does not sputter or hesitate. It is just a little laggy until the compressor disengages when you hammer the throttle. And if you do that I can literally watch my gas needle drop...its crazy.
