engine lacking power on takeoff
Old Jul 4, 2010 | 04:14 PM
patrick_saunders's Avatar
patrick_saunders
Default engine lacking power on takeoff
hey everyone, so one day i decided to pressure wash under my hood to keep it clean, ever since that day ... my car occasionally stumbles trying to get going like it is choking out...
i am thinking :
-my alternator is fried, and the engine isn getting enough amps to run correctly
(ps i have a big stereo too...)
-or my egr is malfunctioning and needs to be replaced...
or both!?
i have a new fuel filter, spark plugs, air filter, and plug wires, and problem persists..
does anyone have a suggestion?
and also has anyone put a bigger alternator on a neon? im thinking a big one!
thanks everyone
Old Jul 4, 2010 | 07:41 PM
Isakill's Avatar
Isakill
If the alternator is fried your battery would be dead constantly.
Is the check engine light on? If so turn the ignition on, off, on, off, and back on within 5 seconds. Where the odometer is at it will flash the codes.. most likely starting with a P.
Old Jul 5, 2010 | 02:13 PM
darthroush's Avatar
darthroush
Section Moderator
Coil pack? You can get an HO alternator, but they are pricey as can be. If an emissions system like the EGR was malfunctioning/not working, you would have a nice, bright yellow check engine light on. Check for codes.
Old Jul 18, 2010 | 06:14 PM
patrick_saunders
thanks for your help everyone, i checked for engine codes and it was a cylinder missfire, turns out one of my brand new spark plugs cracked! so anotyher set of sparkplugs and everything seems a okay again.
thanks again everyone!
