Best RPM to shift at???
Old Jul 18, 2010 | 04:18 PM
bkennedy1289's Avatar
bkennedy1289
Default Best RPM to shift at???
I have a 2000 Neon Highline with a 5spd manual.. I just installed a new tach and it has a shift light, so I was wondering, which rpm for the stock SOHC 2.slow L 4cyl be the best to shift at if I were trying to pick up speed rather quickly?? I'm not talking about gas conservation either, I'm saying if it were on a drag strip(closed course of course ) where would I want that needle when the light comes on??
Old Jul 18, 2010 | 04:19 PM
bkennedy1289
i read that it's at it's max hp @ 5500rpm... that's what I have it set to, but idk if that would be correct....
Old Jul 18, 2010 | 05:49 PM
darthroush's Avatar
darthroush
Section Moderator
Find a spec sheet and shift at the RPM where max torque is achieved. You are going to want the light to come on just a bit before so you have time to react and make the shift.
EDIT: Here's from Motor Trend:
Power: SAE and 98 kW , 132 HP @ 5,600 rpm; 130 ft lb , 177 Nm @ 4,600 rpm
You are looking at ~4,600 RPM
Old Jul 18, 2010 | 05:53 PM
bkennedy1289
Thanks
Old Jul 21, 2010 | 03:04 PM
ottoretto's Avatar
ottoretto
shift the car at 6200 rpm...! the best rom for shifting.... if u feel the car a lil slow when you get the an upper shift, shift at 6400!
Old Jul 21, 2010 | 08:14 PM
darthroush's Avatar
darthroush
Section Moderator
Yeah, scratch that peak torque thing, actually. There is actually a formula to find the optimal shift points. The torque is part of it, but there is more. That peak torque just shot into my head as the answer, but it completely makes sense that it is incorrect. I needed to be thinking of torque across the board.
Here's a pretty good post somewhere else explaining it, simply:
http://www.rx7club.com/showpost.php?...63&postcount=7
Old Jul 23, 2010 | 12:54 AM
ottoretto's Avatar
ottoretto
well... in drag racing you just don't need to how the car acelerate in a gear, you need to know what going to happen when you engage the upper gear, where is going to be the powerband... is more like, shift high for get a good power on the upper shift, but not to much for loose power in that gear.... In a 2.0 DOHC engine the best shift point is at 7100 rpm, yeah is pretty high, but the car run a lot better... but if you use an 2.4 DOHC N/A you have to shift at 4800 or 5000 rpm, beacuse the torque is higher than the hp!...
Old Jul 23, 2010 | 01:52 AM
darthroush's Avatar
darthroush
Section Moderator
Yeah, that is what I wasn't thinking of at the time. It's the "optimal" torque point in the current gear that is going drop you into the next gear's powerband, as you said. You just don't want to under, or over, shift it. Using that formula in the link, you could figure out the best point for each gear.
Old Jul 23, 2010 | 12:23 PM
LowSlowNeon's Avatar
LowSlowNeon
When I used to drag race I used to shift somewhere between about 6200-6600. I would just shift when I could feel the power really dropping off. If you shift to low your car will bog/chug for a bit which isn't a big deal for normal driving but it is when you're going for time.
Old Jul 24, 2010 | 06:22 PM
ottoretto's Avatar
ottoretto
you are right slowneon hehe!.... on my 98 sohc i shifted at 6700, i was using dohc pcm, and the car responded really great, but just 1th, 2nd, and 3th, as darthroush say, the car not always have the same "perfect shift rpm" at all gears!
