Gauges eratic at startup
Old Jul 20, 2010 | 01:00 PM
briann510's Avatar
briann510
Default Gauges eratic at startup
Started car after stopping at the store and gauges went wild.
Car started fine and ran fine but as soon as it started all the gauges pegged to the max and back to min several times, then they all maxed for a moment and all of them then went towards their correct readings but stopped in sync with each other at like 70%, 40% 20% in perfect stepped reductions. It was bizarre like the whole gauges system was performing some kind of test on them. Didn't affect the running or driving of the car. No other idiot lights lit up while this was happening.
If this is the start of electrical gremlins im offing this thing on a trade in this week!
Old Jul 21, 2010 | 12:48 AM
darthroush's Avatar
darthroush
Section Moderator
Have the battery checked. Those are usually the signs of a going battery if the alternator works correctly. Gauges will sweep during a low-battery start up. It'll get worse if it is a bad battery.
Old Jul 21, 2010 | 09:27 PM
briann510's Avatar
briann510
Yup Its the battery! Now when I change the battery I can do the trans mount at the same time!
Old Jul 22, 2010 | 12:06 AM
darthroush's Avatar
darthroush
Section Moderator
There ya go!
