Turbo Kit Question
Old Aug 8, 2010 | 05:39 PM
00Neon89's Avatar
00Neon89
Default Turbo Kit Question
Alright befor you guys go calling this ebay turbo kit crap all i want the kit for mostly is the mani piping mostly and possible downpipe i have plenty of turbos laying around in good condition but looking for someone to answere questions.
So question one if i do get this kit could i also just run a MS with it do i still need to get 30lb injectiors i only plan on running like 8lbs of boost. Also prolly going to look at getting the Walboro 255 Fuel Pump.
And question two what else would i need to have this set up run good i already have someone able to tune with dyno in mind just need to check if he knows MS. So basicaly what im looking for is a list of things i would need.
Here Is the Kit Name i cant post links for some reason.
Rx Racing “Street Demon” Series 485HP Package(found on ebay)
Old Aug 9, 2010 | 10:11 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
to answer your questions.... first u WILL want to get injectors for your car if u go boost, and yes you can run ms with that setup. go with the walbro 255 intake pump, and spool boy mod... no need to do a return if running low boost.. but a good idea to add it anyway.. NEVER short out on fuel when it comes to a turbo app... if so hope u have a spare engine sitting around.
well if u want to go with just getting the turbo manifold and intercooler piping why dont u just get those things seperate and save ur self some money?
decent intercooler kit.
http://cgi.ebay.com/ebaymotors/2-5-I...ts_Accessories
are u going internal or external wastegate?
internal
http://cgi.ebay.com/ebaymotors/T3-T4...ts_Accessories
external, could not find link, and am short on time.
list of things u would need as in parts to do a complete kit? or just ms?
ms u will need ms2, wiring harness, and gm sensors and pigtails, gm intake air temp, and coolant temp to be exact,
if u need a list of all the parts needed for a turbo set up, use the search function.
Old Aug 25, 2010 | 01:44 PM
Breeze's Avatar
Breeze
theres a MS thread and a turbo thread on here that the Admin has put up...def good idea to check that out... i was gunna do the same thing about a yr ago and had to put it on hold...but if u have a stock srt turbo layin around and its in good shape pm me....also i heard that the tranny's are weak when it comes to the torque when u boost so...jus a heads up prepare for a tranny swap/upgrade
