cylinder head swap
Old Aug 19, 2010 | 04:55 PM
pacolaco77's Avatar
pacolaco77
Default cylinder head swap
i have been thinking about swapping out the cylinder head on my 05 neon sxt. it's a 2.0L and i was wondering if i could use 2.4L head on it. and if i can what do i need to make it work. and if possible around how much would it cost me.
Old Aug 26, 2010 | 02:09 AM
neonftw87's Avatar
neonftw87
im thinking it will bolt up, but your neon is SOHC, and the 2.4 is DOHC... so you would need a timing belt for sure, and iono if the wiring harness is the same or not, youd have to check on that, and the cam positioning sensors.
