Ground Strap on Negative Batt Cable for 2003 Neon
Old Aug 9, 2010 | 07:04 PM
steevo96's Avatar
steevo96
Default Ground Strap on Negative Batt Cable for 2003 Neon
Hi everyone. I'm brand new to this forum.
I recently purchased a 2003 Neon 4 speed auto that needed a new engine. I just finished replacing the engine and I got everything back where it is supposed to go except the groundstrap on the negative battery cable. I don't remember exactly where it went. Will someone please tell me where this is supposed to go? A pic would be nice if it isn't too much trouble. I want to make sure everything is put back where it came from.
Thanks in adavance.
Steevo
Old Aug 10, 2010 | 12:30 AM
darthroush's Avatar
darthroush
Section Moderator
There are two grounds that go to the battery. There is the one on the driver side fender and the other goes to...somewhere else. I can get pics tomorrow if you want.
Old Aug 10, 2010 | 06:37 AM
leprechaun1874's Avatar
leprechaun1874
my 02 the ground is right behind the trans fluid tube I believe. looking at the tube it would be just to the left.
Old Aug 26, 2010 | 02:17 AM
neonftw87's Avatar
neonftw87
i attach mine to the bolt that holds the starter on, and the other to the fender.. Just as long as the engine is tied to the body.
