Low-Beams
Old Aug 12, 2010 | 12:59 AM
lspaintballer's Avatar
lspaintballer
Update: Im having my dash and lights in side flickering and once my high beams are on same problem. Also If I turn all my lights in the car or my high beams the car just dies. Is that a battery problem?
Old Aug 12, 2010 | 03:17 PM
showsxt's Avatar
showsxt
Could be the alternator or alternator belt or battery you can go to autozone and have the battery checked and get that out of the way and go from there.
Old Aug 13, 2010 | 01:07 PM
BroodRed's Avatar
BroodRed
Originally Posted by Isakill
Melted?
that's interesting.. What all did you have to do in order to take it out?
Cause it seems I need to replace mine soon.
Last night I cleaned the harness plug(the bottom of the plug was melted a bit, but it still has the metal connections) and the MFS unit and put them back together and viola! my headlights work again. I believe it's from using different wattage bulbs in either your headlights or fogs. Either way, I'm installing standard blubs from now on.
Old Aug 13, 2010 | 01:28 PM
lspaintballer
Oh whats the right voltage?
Old Aug 13, 2010 | 01:46 PM
Isakill's Avatar
Isakill
doesn't have anything to do with the voltage.. it's all 12 - 15 volts (depending on how much your alternator is putting out.
It's about the current the bulbs are using.
P (wattage) = Amps(current) x Voltage
You use higher wattage bulbs they use more amps. Thus the melted harness. Because any connection in a wire adds resistance. resistance makes heat.
Old Aug 13, 2010 | 02:20 PM
lspaintballer
Oh sorry ment to say wattage, cause currently I'm using 12v/100w ebay lights.
Old Aug 13, 2010 | 02:43 PM
darthroush's Avatar
darthroush
Section Moderator
The problem is you are using a bulb that is rated at twice the legal wattage. Low beams are 55W. High beams are 65W. 100W is off-road use only because it WILL blind oncoming traffic. You also need a dual filament bulb as the one bulb produces both the low and high beams. Go to the store, buy proper bulbs, and try it.
Old Aug 13, 2010 | 03:08 PM
lspaintballer
ah kk but low beams should still work for 100w tho?
Old Aug 13, 2010 | 03:45 PM
BroodRed's Avatar
BroodRed
Never use 100w bulbs in a Neon. I use Sylvania golds.
You don't use 60w bulbs in a lamp if it only says 40w, right? It's the same for a car's headlights.
Old Aug 13, 2010 | 04:17 PM
darthroush's Avatar
darthroush
Section Moderator
All I know is using that high of a wattage bulb, you run the risk of catching the factory wiring on fire and/or melting it, heck, possibly even melting the housing. The factory wiring is not made for that kind of bulb.
