Low-Beams
Old Aug 11, 2010 | 12:25 AM
lspaintballer's Avatar
lspaintballer
Default Low-Beams
My low beams arn't working. I replaced new bulbs but still isn't working. Do anyone of you guys have an idea what the problem might be? Thanks in advance.
Old Aug 11, 2010 | 03:30 AM
darthroush's Avatar
darthroush
Section Moderator
It could be the MFS and/or the wiring.
Old Aug 11, 2010 | 10:10 AM
Moparkyle's Avatar
Moparkyle
Take a look at the sockets too, maybe give them a good cleaning.
Old Aug 11, 2010 | 01:55 PM
lspaintballer
Oh okay thanks, what is MFS by the way?
Old Aug 11, 2010 | 02:00 PM
BroodRed's Avatar
BroodRed
Multi Function Switch. The turn signal lever that the headlight control is on. Mine just went bad and I'm looking to replace it.
Also, check your fuses.
Old Aug 11, 2010 | 02:14 PM
lspaintballer
Oh I see Ill check that out but everything seems to work with the switch, the yellow lights work when low beams are on position, if that's normal.
Old Aug 11, 2010 | 02:42 PM
Moparkyle's Avatar
Moparkyle
It could still be the switch, when it goes bad funny things happen.
Old Aug 11, 2010 | 05:48 PM
BroodRed's Avatar
BroodRed
I just removed my MFS. The unit seems to be okay, but the plug on the harness is kindof melted. I'm going to take it to a friend's shop to see what he can do.
Old Aug 11, 2010 | 08:22 PM
Isakill's Avatar
Isakill
Melted?
that's interesting.. What all did you have to do in order to take it out?
Cause it seems I need to replace mine soon.
Old Aug 11, 2010 | 08:57 PM
showsxt's Avatar
showsxt
Well you guys are having headlight problems and for like two yrs now I have been running without foglights I have the halos projectors so probably something to do with the wiring not the mfs in my case.
