New Guy
Old Dec 6, 2010 | 07:10 PM
  #31
ryderrolle's Avatar
ryderrolle
okay guys I'm completely baffled, got the heating issue solved but now i've got major problems. My oil light constantly comes on but the oil level is good and now the car shuts of and it seems as if it's a lack of fuel but I'm at a half of tank. I let the car sit a bit and sometimes it starts and runs fine but most of the time it starts for about 2 minutes and shuts back off, any ideas?
Old Dec 6, 2010 | 11:17 PM
  #32
hemi4spd's Avatar
hemi4spd
oil pressure sending switch is shot or the wiring to it is bad
just a hunch
this precieved condition of no oil could make the computer think to save this engine i better turn off the fuel.
Old Dec 7, 2010 | 01:42 AM
  #33
darthroush's Avatar
darthroush
Section Moderator
The oil pressure sensors are a common fix on these cars. I've never heard of these cars shutting off when the oil light comes on though...
Old Dec 7, 2010 | 05:03 PM
  #34
ryderrolle's Avatar
ryderrolle
where can i find the oil senor, what do i need to take it out and how difficult is it to remove or get too
Old Dec 7, 2010 | 07:06 PM
  #35
darthroush's Avatar
darthroush
Section Moderator
Behind the engine. You need a 1 1/16" deep socket to get it out. It's kind of a PITA, but then again, I'm a bigger guy so reaching around everything wasn't too easy for me. Like a 3 or so out of 10, just because it's a PITA to get to.
Old Dec 7, 2010 | 10:18 PM
  #36
hemi4spd's Avatar
hemi4spd
not hundred precent sure if the neon shares this failsafe (most likely may not) but Ive seen higher end cars, and construction equipment have this protection feature to prevent running the engine without oil pressure.
Old Dec 7, 2010 | 11:02 PM
  #37
darthroush's Avatar
darthroush
Section Moderator
Yeah, no fancy crap on these things, lol.
Old Dec 13, 2010 | 04:20 PM
  #38
ryderrolle's Avatar
ryderrolle
okay, i got the oil sensor out, was real easy once i took out the battery and took of the heater core hoses but now I'm leaking oil from the sensor. Any Ideas as to what's going on, oh and the oil light has gone away
Old Dec 13, 2010 | 05:58 PM
  #39
neown420's Avatar
neown420
did the oil pressure sensor come with a o-ring or gasket ? not sure if theyre supposed to but just a thought
Old Dec 14, 2010 | 01:40 PM
  #40
darthroush's Avatar
darthroush
Section Moderator
It comes with a very small amount of thread sealant on it (the Dodge one does anyways). Did you put any [extra] thread sealant on the threads? If not, that and just make sure it is snugged well.
