**NO BUS** error
Old Sep 5, 2010 | 05:59 AM
darthroush's Avatar
darthroush
Section Moderator
I have seen that a No Bus message usually means a bad computer, bad crank sensor, bad cluster or a wiring problem. Are you sure no wiring got damaged in the swap? All fuses are good, everywhere? The crank sensor is getting 5V, as it needs?
