Need help..another hummimg thread ..look inside
okay driver side ..humming like a mother f..you get the point..heres what i did ..
changed axle.did wheel bearing.new rotors and brakes .checked wheel ,tire pressure and balance..****s driving me crazy..
okay when i turn slightly to the right no more humming .going straight and making left turns humming is loud...whats left tie rod, power steering pump ..or just make right turns only..???
thanks........
thanks........
it could be shocks just because that same thing happened to me and i changed them like 4 years ago and that fixed the problem and i recommend you put some after market shocks do not use the stock shocks and struts they sell and autozone or just from ebay. and about the power steering pump that is not the problem and my reason is because if your power steering pump is going bad you will hear that grinding and loud noise all the time not only when you turn to the left or go straight. Hope i helped you out if you have any questions let me know
Cheers mate
Cheers mate
sorry to mention.. i did change the struts thanks for the suggestion i taught about that too.i have tokico blues and srt 4 oem struts and i swapped them around..still the same problem..only thing now i can think is what DARTHROUSH mention motor mounts or torque struts and maybe the tie rod..after iam done with the left side of this car it will cost more than the car itself..lol..cant wait to spend more money on my wifes car..she loves her little neon ..now she wants a upgrade her music system..where will it end..
My motor mount was bad. My car vibrated, buzzed, rattled, made noises and more. It was like driving a new car once it was replaced. I actually smiled the whole drive home and the quietness, besides the exhaust, lol. That's why I ask.
if aint broken i will wait ..i want to fix which i think might need changing ..engine mounts and tie rods..hopefully it will solve my problem..thanks for the inputs guys..
