Clutch problem!!
Old Sep 10, 2010 | 11:31 PM
CTremble's Avatar
CTremble
Default Clutch problem!!
We went to a friends house tonight for dinner. On the way there I felt something pop in the clutch when I was getting on the interstate. When we got off I could not shift anymore.
I can push the clutch all the way in but it feels as if it is a dead pedal, no force to push it in or let it out. The only way I can put it in first is if I turn off the car, put it in first then start the car and it wants to roll as I am starting, and that is with the clutch pedal pushed all the way in.
I am wondering what it could be? Clutch cable, Clutch Master Cylinder, Linkage cable, or it needs to be adjusted?
I have a 2004 Dodge Neon SXT 2.0 SOHC, 5 spd M/T
Any help would be a great start to help self diagnose this problem before taking it in to the tranny shop!
I am very car savvy and rather fix something myself before having to pay hundreds, even thousands of dollars for something I could do for 75% less. This one has me stumped and I could really use the assistance
Old Sep 10, 2010 | 11:33 PM
CTremble's Avatar
CTremble
Oh and I can shift, but I have to be going at a certain speed and then lightly tap the gas to make it engage that gear. Baby'd the beast all the way back home without a clutch. Trying to use the clutch is worthless other than just starting the car up which I will not be doing until I can find out what is wrong.
Thanks again
Old Sep 11, 2010 | 11:23 AM
sapporo's Avatar
sapporo
it's obvious the clutch is not releasing. one of the most common problems I've had with similar situation as you are explaining is having a disc hub spring pop out and jamb in the pressure plate.
KISS diagnosis, check cable, look at arm to see if it's moving.
