Neon not getting a spark
Old Nov 24, 2010 | 01:13 AM
neown420's Avatar
neown420
yeah the grounds are hooked back up, only had to disconnect 1 while changing the mounting bracket. i got a mechanic(yes a legit mechanic) coming by to take a look tomorrow. ill see what he can find and update you
*edit*
he woke up late and has too much **** to do today so hes coming by tomorrow -.-
Old Nov 28, 2010 | 01:26 PM
neown420's Avatar
neown420
the mechanic friend came by on thanksgiving and was not able to find anything wrong :/ hes gunna call some friends and hope to get steered in the right direction.
now another thing i just found out via txt msg is that there is a slight possibility that this ***got *** kid that has problems with me for no reason may have got someone to put sugar in my gas tank. would this cause the car to not spark ? or just not start? and how easy is it to drain the gastank to check since i didnt really see any sugar particles around the gas fill spot
Old Nov 29, 2010 | 01:06 PM
hemi4spd's Avatar
hemi4spd
ok ok now ive heard em all. sugar in the tank is a old wives tale, do you know how many bags of sugar it would take to block the pickup?? the answer is more than the ***got *** kid has the patience to pour in. even if there was enough sugar put into your tank there would still be spark, just no fuel as the pump would be blocked by sugar sludge.
Btw if you really wanna screw with someones gas use plain water, about 1L is more than enough as gas is lighter than water the pickup will be surrounded by water and not fuel, but u never heard that from me lol
Old Nov 29, 2010 | 05:54 PM
showsxt's Avatar
showsxt
Oh I have had some kids put worse stuff in my gas tank and she ran really bad so had to put that gas cleaner in and that did the job with clean gas. So I would just get some gas cleaner and try that and maybe just wait for your friend to pin point the problem for you.
Old Nov 29, 2010 | 11:10 PM
darthroush's Avatar
darthroush
Section Moderator
Have you tested the sensors with a multi-meter yet?
Old Dec 1, 2010 | 01:38 AM
neown420's Avatar
neown420
ive been broke till today but im gunna try to go out and get the multimeter today. its raining here so i dont think ill be able to go test them till tomorrow but we'll see.
Old Dec 2, 2010 | 12:23 PM
neown420's Avatar
neown420
ok so im outside freezing my butt off and idk what to do. i have a multimeter, but how exactly am i supposed to test this crap? do i leave the plugs connected ? or disconnect the plug and stick the red wire into the plug ? or leave the plugs connected and stick the wire into the back of the plug where the wires are slightly exposed ? if so then its impossible to check the cam sensor w/o unplugging due to chryslers dumb idea of cramming as much BS in each spot as possible. need a quick reply here please =]
Old Dec 2, 2010 | 12:31 PM
darthroush's Avatar
darthroush
Section Moderator
You should be able to undo the plugs? I've never done real in-depth testing, but the same amount of voltage should travel along the entire length of wire if you are simply testing for power/ground.
Old Dec 2, 2010 | 12:33 PM
neown420's Avatar
neown420
ok thnx for the fast reply darth, also im pretty sure but just wanna be 100% sure. i turn the key to the on position to test the plugs, correct ?
Old Dec 2, 2010 | 12:45 PM
darthroush's Avatar
darthroush
Section Moderator
Yessir, that way you have the required power/voltage. I'm heading out the door in a few minutes, so if I don't reply back after this...that's why.
