Neon not getting a spark
Old Nov 13, 2010 | 04:40 PM
neown420's Avatar
neown420
Default Neon not getting a spark
i have a 00 neon and i just replaced the motor mount bracket and 2 transmission hoses. in the process of moving the motor up and down to get the mounting bracket off im thinking it may have damaged a wire possible ? i changed the distributor and checked the fuses. there is no spark coming out at all and before i did any work it never had any ignition problems.
Old Nov 14, 2010 | 02:47 AM
darthroush's Avatar
darthroush
Section Moderator
I am curious how you changed the distributor on a car that doesn't have one? Start looking for damaged/dangling wires...
Old Nov 17, 2010 | 01:13 PM
neown420's Avatar
neown420
my bad, the ignition coil is what i switched out. cant find any bad wires so far and all the grounds are connected. could it be a bad crankshaft position sensor or any other sensor in the ignition system causing this? i really need to get my car back up and running :/ or is there any other way to find out why its not putting out a spark ?
Old Nov 18, 2010 | 06:42 PM
hemi4spd's Avatar
hemi4spd
check the cam and crank sensors, you may have disturbed them when doing the mount. Any CEL?
Old Nov 22, 2010 | 03:49 PM
neown420's Avatar
neown420
i checked both of them even tho im not sure what im looking for. the plugs look completely fine and the wires running to them are fine. how could i tell if either of these sensors just decided to fail after changing a mount bolt ? :/ keep in mind the cam pos sensor is in the worst spot to get to with all the hoses and wires in my way -.- and the crank sensor isnt much better with the axel and frame in the way. also baught a brand new coil pack and brand new battery(old battery went bad failing to start my car) and still didnt help. and what do you mean any CEL ?
Old Nov 23, 2010 | 03:41 AM
hemi4spd's Avatar
hemi4spd
CEL= Check Engine Light
check the sensors for ground, and voltage. You can do this with a cheap multimeter
ur looking for 8volts on the orange wires and the black/Lt Blue wire is the ground, the grey/black goes back to the computer
same wire colours for both sensors
Old Nov 23, 2010 | 02:34 PM
neown420's Avatar
neown420
am i checking the sensor itself or the wires running into it, sry never had to test a sensor before. would appreciate a nice description on how to do so =] i have a circuit tester(i think). also yeah the CEL is on but for 0743(torque converter circuit malfunction, been there since i got the car and after i swapped trannys and torque converter.) and 1684? which means battery been disconnected in last 50 starts.
Old Nov 23, 2010 | 03:13 PM
hemi4spd's Avatar
hemi4spd
buy a multimeter, you can get one for like 20-30 bucks, doesnt have to be made by FLUKE or anything.
a circuit tester will tell you there is or isnt juice but will not tell you how much juice is present.
with the key on you should see 8 volts on the orange wires, put your black lead of multimeter to ground and the red lead to the orange wire, check results.
if you have 8 volts there,
you can know the sensor is getting power.
Now switch your meter over to the setting for checking continuity and place a lead to the black wire at sensor and a good ground, should see continuity, telling you that the ground wire is in fact intact and connected.
thry those 2 tests and see whats what. your basically just checking the wiring to the sensors at the moment, electricity is a funny thing its there even though you cannot see it, this is why we need a meter to see it.
wires can visually look great but not flow or have any juice in them.
Old Nov 23, 2010 | 04:43 PM
neown420's Avatar
neown420
lets say im too poor to get one at the time, what are the odds of anything happening to either of these sensors while moving the motor 4-5 inches on one side ? the car had absolutely no problem starting before any of this.
Old Nov 23, 2010 | 08:58 PM
darthroush's Avatar
darthroush
Section Moderator
It doesn't matter what the odds are; if it is the sensors, it's the sensors either way. They should be checked. Are you positive all grounds are hooked back up and have you tested the sensors yet?
