2005 dodge neon sxt---please help!
Old Dec 17, 2010 | 04:30 PM
zacharysmommy24's Avatar
zacharysmommy24
Default 2005 dodge neon sxt---please help!
I am having problems with my car idling high.Rpms go up to 5000.You can hear the engine revving real loud.When I try to brake the car jumps forward and is having trouble coming to a stop.I went to autozone and the code came up p2074.What does it mean and how can I fix it?
Old Dec 17, 2010 | 06:24 PM
neown420's Avatar
neown420
sounds to me like a bad vaccuum leak. read on another page that that code means a big vaccuum leak. check all the plastic hoses that run from the engine and airbox and whatnot for wear holes or even cracks. if thats all it is it will be a simple fix, hope this helps
Old Dec 17, 2010 | 06:43 PM
darthroush's Avatar
darthroush
Section Moderator
Vacuum leak. Be sure to check the PCV line; that is the big one.
Old Dec 17, 2010 | 07:40 PM
hemi4spd's Avatar
hemi4spd
check that breather tube for splits as well
Old Apr 29, 2011 | 10:04 AM
04dodgeneonsxt's Avatar
04dodgeneonsxt
could be a throttle body problem i would check and see if it has any holes or if the connection is tight
Old Apr 29, 2011 | 11:02 AM
krain88's Avatar
krain88
Mine did somewhat the same thing and I had a vac leak rpms didn't jump as high but the vac elbow that come out of the tb is what caused it
Old Apr 30, 2011 | 03:05 PM
Moparkyle's Avatar
Moparkyle
Does the brake pedal feel hard?
Old Oct 9, 2012 | 08:36 PM
muzokh's Avatar
muzokh
Default Getting Code P2074
I changed my starter and front break pad and after that I am getting the title mentioned code. Please advice. Thanks
Old Oct 10, 2012 | 02:03 AM
neown420's Avatar
neown420
Check to make sure you reconnected all the vacuum hoses(specifically the one that connects directly to the intake manifold and valve cover since thats in the path of working on the starter) make sure none of them have any small holes or cracks in the connectors
Old Oct 10, 2012 | 07:10 PM
Moparkyle's Avatar
Moparkyle
Did you remove the intake manifold to replace the starter?
