Just a question
I have a 2004 Dodge neon SXT. My engine light is on and the code is telling me P0441. I also need engine mounts. And a new timing belt I think. I have almost to 120,000 miles on the car. And dont know what else needs to be fixed. So my question is... Should I get another car or fixed what I think is wrong? Which would be the cheaper thing to do?
+1 darth those are wear items
the evap code wont affect the way the car runs (unless you a member of greenpeace dont worry bout it right now) just ignore the light and worry about it come emission test time.
do the mounts and the timing belt and you'll have way more money than buying a new car.
check the tubes from Carbon Canister to Purge solenoid, then from purge solenoid to throttle body very closely if they leak anywhere along there will set that code
whats a NVLD pump?
whats a NVLD pump?
Natural Vacuum Leak Detection pump.
The Natural Vacuum Leak Detection (NVLD) system is the next generation evaporative leak detection system that will first be used on vehicles equipped with the Next Generation Controller (NGC). This new system replaces the leak detection pump as the method of evaporative system leak detection. This is to detect a leak equivalent to a 0.0209 (0.5 mm) hole. This system has the capability to detect holes of this size very dependably.
