Rod Bearings
Old Jan 17, 2011 | 01:06 PM
silentdub's Avatar
silentdub
Default Rod Bearings
I have to replace the rod bearings on a 04 neon 2.0L.
Does anyone have the torque specs?
Are the bolts a 1 time use, or can I reuse them?
Old Jan 17, 2011 | 01:28 PM
silentdub's Avatar
silentdub
for a mere .70 cents each, I ordered new ones.
anyone know the torque spec for the rod bolts?
Old Jan 17, 2011 | 09:33 PM
hemi4spd's Avatar
hemi4spd
rod bolts are to be done in two steps
1st step torque to 20FtLbs (27Nm)
2nd step turn an additional 90 degrees
so the torque value is not really that accurate(I know crazy huh?)
Old Jan 17, 2011 | 11:29 PM
Moparkyle's Avatar
Moparkyle
The 90 degrees is the factories way of making sure the spec is close in case someone is using a misadjusted torque wrench or what have you.
Old Jan 20, 2011 | 09:25 AM
silentdub's Avatar
silentdub
Thanks guys, did it last night.
I thought the extra turn was for the 'stretch bolts' they stretch a little bit to keep them tight, not sure how it works.
I replaced the bolts anyway.
Old Jan 20, 2011 | 12:05 PM
hemi4spd's Avatar
hemi4spd
im pretty sure they dont use torque to yeild(TTY) bolts on a crank, heaven forbid if they stretched and let go,
Old Jan 23, 2011 | 09:54 PM
Moparkyle's Avatar
Moparkyle
Yeah they usually use TTY on Head bolts.
