swaybar size
Old Jan 23, 2011 | 11:44 PM
Mr. Gabriel M's Avatar
Mr. Gabriel M
Default swaybar size
What size are the swaybars on a 05 srt4 neon?
What size is the swaybar on a 03 sxt neon?
Old Jan 24, 2011 | 01:30 AM
darthroush's Avatar
darthroush
Section Moderator
SRT-4: 24mm front and 17mm rear.
Non-SRT: Either 20mm or 22mm front; the 20mm the most common.
Old Jan 24, 2011 | 02:01 AM
Mr. Gabriel M
Thanks
Old Jan 25, 2011 | 08:15 PM
SRT-OSO's Avatar
SRT-OSO
Do the SRT4 sways fit the regular cars without any mods? Not sure if the mounts are reinforced or something.
Old Jan 26, 2011 | 01:19 AM
darthroush's Avatar
darthroush
Section Moderator
On the fronts, yes. After 2000, Dodge got rid of the rear strut mounting tabs so you can't just bolt them up.
Old Jan 27, 2011 | 10:41 PM
Moparkyle's Avatar
Moparkyle
I got quickstruts from Napa for the rear, they come with the swaybar mounting bracket FYI.
Old Jan 28, 2011 | 02:58 AM
darthroush's Avatar
darthroush
Section Moderator
They are aftermarket struts
Old Jan 29, 2011 | 06:35 PM
Moparkyle's Avatar
Moparkyle
Yes, just a suggestion if you wanted to get that rear sway bar. Although the OEM strut mounts have 3 studs and the Napa one comes with 2 studs and a screw which was a PITA.
Old Feb 1, 2011 | 12:51 PM
thecause17's Avatar
thecause17
What size bars are on the R/T's? I don't think they're the same size as the SRT-4 right?
Old Feb 1, 2011 | 12:55 PM
darthroush's Avatar
darthroush
Section Moderator
Read post #2
