2004 Neon SXT Idler Puller Replacement
Old Feb 6, 2011 | 12:30 PM
MacTen's Avatar
MacTen
Default 2004 Neon SXT Idler Puller Replacement
Anyone have an idea of what it should cost to have the idler pulley replaced..... AC/Power steering idler pulley that is.
Old Feb 6, 2011 | 03:43 PM
darthroush's Avatar
darthroush
Section Moderator
The book says 2.4 hours, so that times whatever the shop charges per hour.
Old Feb 10, 2011 | 08:29 PM
DTF04's Avatar
DTF04
how do you replace the Drive Belt Tensioner?
Old Feb 10, 2011 | 08:56 PM
darthroush's Avatar
darthroush
Section Moderator
The pulley can be replaced, the tensioner cannot. If the tensioner itself broke, you need an entire engine mount plate/bracket.
Old Nov 13, 2011 | 09:12 PM
George Mcfarland's Avatar
George Mcfarland
New Member
how do you replace the idler pulley?
Old Nov 13, 2011 | 09:17 PM
George Mcfarland
New Member
Default idler pulley replacement
how do you replace the idler pully? I have torn down the left side of the 2002 neons engine. got to the pulley and could not get a torx drive bit to break it loose? any suggestions?
Old Nov 14, 2011 | 03:10 AM
darthroush's Avatar
darthroush
Section Moderator
Try soaking it with PB Blaster?
