Stops running sometimes won't start!
Old 02-28-2011, 01:08 PM
buddhaman's Avatar
buddhaman
buddhaman is offline
just for the fun of it, do a code check to see if the brain is working
Old 02-28-2011, 07:14 PM
hemi4spd's Avatar
hemi4spd
hemi4spd is offline
sounds likes its right in the ignition switch
Old 03-01-2011, 01:04 PM
doug5g's Avatar
doug5g
doug5g is offline
FIXED! Between the lock cylinder and the ignition switch there is a connecting rod assembly. I don’t know its real name. But this rod was broken. $5 from a junk yard and we are back in business.
Old 03-02-2011, 02:04 AM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
Dodge Forum Moderator
Usually called an ignition switch rod.
Old 04-23-2011, 08:26 PM
doug5g's Avatar
doug5g
doug5g is offline
It ended up being the assembly the ignition lock cylender sits inside.
Old 05-22-2011, 12:40 PM
badass318's Avatar
badass318
badass318 is offline
when there is nothing to the coil pack i would try to see if the crank position sensor is bad.
badass318's Avatar
badass318
tough some vehicles i think its a cam position sensor, im not sure. google it and see
Old 05-22-2011, 04:14 PM
darthroush's Avatar
darthroush
Section Moderator
Old 05-22-2011, 05:32 PM
Moparkyle's Avatar
Moparkyle
Moparkyle is offline
Yeah I was gonna leave that one alone haha.
Quick Reply: Stops running sometimes won't start!
