I'm at a loss here :-(
Old Mar 26, 2011 | 01:02 AM
steak59's Avatar
steak59
I think you should just go buy a Code reader, instead of risking getting Stuck at Autozone's parking Lot.
Maybe it Jumped time? But having the Code definitely helps.
Old Mar 27, 2011 | 10:10 PM
me0418840987's Avatar
me0418840987
Check the wires that go to the Idle air valve. Mine had a break in one of the purple wires going to it. Had all of the same symptoms yours had, right down to the fuel smell. The problem was intermittent at first, but finally came back and would not go away. Fixing the wire fixed the problem. Runs great now with 235,000 mi on it.
Old Mar 29, 2011 | 01:01 AM
CyrilKeir's Avatar
CyrilKeir
Originally Posted by mypoorneon
...while sitting at a light i noticed my RPM's drop significantly and the car was about to die just before it picked back up again and seemed to run fine but there was a definite "fuel" smell coming from the exhaust...
My first thought was it acted like it wasn't getting any fuel. OH...cylinder 3 has a bit of oil in it which I read is
What I quoted, is exactly what my neon is doing. It's not doing the other issues your neon is doing, so what is the exact fix for the above quoted issues?
Old Mar 29, 2011 | 03:54 AM
Kal13's Avatar
Kal13
Idle air controller (IAC)
Old Mar 29, 2011 | 01:40 PM
opie9797's Avatar
opie9797
Default plug knock
change your spark plugs neons blow plugs all the time when your car was running fine did u hear a little knock from the engine its called a plug knock i had to change my plugs once a yr to keep it from stalling out
